WHOIS Error: 110 - Connection timed out - WHMCS - บอร์ด ชุมชนคนทำเว็บ
« เมื่อ: 23 เม.ย. 2016 »
login SSH
Opening Ports In Your Firewall
Occasionally you will find that you need to open up a port in your firewall for some application or another. Depending on which firewall is installed on your server, there are several ways to go about this:
APF
Unfortunately, APF can only be configured by accessing the server over ssh, as the root user.
Once in your server, open the following file in your favorite text editor:
/etc/apf/conf.apf
Use your editor’s search function to find the following line:
# Common inbound (ingress) TCP ports
IG_TCP_CPORTS="20,21,22,25,53,80,110,143,443,465,993,995"
Besides this ingress TCP entry, you should also see similar lines for UDP and ICMP ports, and outbound (egress) entries for all three packet types. For the most part, when a program needs a port opened, it needs inbound TCP opened. If you open the port following these article, and you still encounter problems, check to make sure the program does not need outbound TCP opened, or another packet type altogether.
Add the port that your program is requesting by adding the port number to the list. Make sure it is separated from other ports by commas.
After saving and closing out of your text editor, you will need to restart APF. This is as simple as running:
apf -r
http://www.liquidweb.com/kb/opening-ports-in-your-firewall/
« แก้ไขครั้งสุดท้าย: 23 เม.ย. 2016 โดย Administrator »
Re: WHOIS Error: 110 - Connection timed out
« ตอบกลับ #1 เมื่อ: 23 เม.ย. 2016 »
CSF
Unlike APF, CSF can be configured in Web Host Manager (WHM) as well as over ssh. The ssh instructions are remarkably similar; open up the following file:
/etc/csf/csf.conf
and add the port you mean to open to the needed line:
# Allow incoming TCP ports
TCP_IN = "20,21,22,25,53,80,110,143,443,465,587,993,995,26"
# Allow outgoing TCP ports
TCP_OUT = "20,21,22,25,37,43,53,80,110,113,443,587,873"
CSF then needs to be restarted for the change to take effect:
csf -r
« ตอบกลับ #2 เมื่อ: 23 เม.ย. 2016 »
Edit ConfigServer Firewall  ใน DirectAdmin Login
csf - ConfigServer Firewall
IPv4 Port Settings
piposeo8
  • 1
« ตอบกลับ #3 เมื่อ: 05 ม.ค. 2017 »
