How to upgrade to CustomBuild 2.0 - DirectAdmin - บอร์ด ชุมชนคนทำเว็บ
« เมื่อ: 11 เม.ย. 2016 »
If you're running CustomBuild 1.1 or 1.2, and you wish to update to CustomBuild 2.0, then update process is not just a matter of changing the options.conf setting, because the values in the option.conf differ in 2.0.
General CustomBuild 2.0 documentation
Older installs, re-run the pre-install commands, in case you're missing something.
1) To update to CB2 with all of the default options, type the following:
cd /usr/local/directadmin
mv custombuild custombuild_1.x
wget -O custombuild.tar.gz http://files.directadmin.com/services/custombuild/2.0/custombuild.tar.gz
tar xvzf custombuild.tar.gz
cd custombuild
./build
2) At this point, the default options.conf would have been created.  If you want to use all of the default options, skip to step 3.  Else, now is when you'd make change to your options.conf.
3) Once you're ready to install what's set, run:
./build all d
./build rewrite_confs
https://help.directadmin.com/item.php?id=555
