How to Updating Apache to the latest version directadmin custombuild - DirectAdmin - บอร์ด ชุมชนคนทำเว็บ
You can check the current version of apache by running
/usr/sbin/httpd -v
CustomBuild - current
If you're using custombuild (as most new boxes are), run the following
cd /usr/local/directadmin/custombuild
./build update
./build apache
./build php n
./build rewrite_confs
CustomApache - end-of-life
If you are using customapache with the 1.3 version of apache to the most recent, run the following:
cd /usr/local/directadmin/customapache
./build clean
./build update
./build apache_mod_ssl
If you're using apache 2.x, use "./build apache_2" instead of apache_mod_ssl.
This should update both the configure options and the version of apache to the most recent version.  Once the update has completed, you'll need to restart apache:
RedHat:
/sbin/service httpd restart
FreeBSD:
/usr/local/etc/rc.d/httpd restart
« แก้ไขครั้งสุดท้าย: 06 เม.ย. 2016 โดย Administrator »
