Install DirectAdmin on CentOS 6 or 7 - DirectAdmin - บอร์ด ชุมชนคนทำเว็บ
« เมื่อ: 19 มี.ค. 2016 »
DirectAdmin is a proprietary web-based control panel that you can install on your server which offers a variety of system-administration features.
In this article, we are going to install DirectAdmin on a CentOS server.
First, make sure that you are logged in under your root user and that you have purchased a DirectAdmin license from their official site.
Update your server so that it has the latest packages:
yum update
Next, we are going to install the packages that DirectAdmin needs on CentOS 6 to run properly. You can do that by executing the following command:
yum install wget gcc gcc-c++ flex bison make bind bind-libs bind-utils openssl openssl-devel perl quota libaio libcom_err-devel libcurl-devel gd zlib-devel zip unzip libcap-devel cronie bzip2 cyrus-sasl-devel perl-ExtUtils-Embed autoconf automake libtool which patch mailx db4-devel
If you are running CentOS 7, run the following commands:
yum install wget gcc gcc-c++ flex bison make bind bind-libs bind-utils openssl openssl-devel perl quota libaio libcom_err-devel libcurl-devel gd zlib-devel zip unzip libcap-devel cronie bzip2 cyrus-sasl-devel perl-ExtUtils-Embed autoconf automake libtool which patch mailx psmisc net-tools systemd-devel libdb-devel
Now, download the DirectAdmin installation script through wget. If you don't have wget yet, then you can install it via the command yum install wget.
wget http://www.directadmin.com/setup.sh
chmod 755 setup.sh
To run the installation script, simply enter in the command:
./setup.sh
Follow the instructions on screen to complete the DirectAdmin installation. You can access DirectAdmin once its finished installing with your web-browser by navigating to http://server_ip:2222.
http://www.woktron.com/secure/knowledgebase/76/Installation-of-Directadmin-on-CentOS-5-and-6.html
« แก้ไขครั้งสุดท้าย: 25 มี.ค. 2016 โดย Administrator »
Re: Install DirectAdmin on CentOS 6 or 7
« ตอบกลับ #1 เมื่อ: 25 เม.ย. 2016 »
setup.sh: Running DirectAdmin from the command line
http://help.directadmin.com/item.php?id=578
